[Лаборатория] Config SQLite
Добавлено: 03 июн 2020, 13:40
Peugeot 308
Albin link
Albin link
CDC: 1
T_EXT: 1
AAS: 1
COUNTRY: 0
OPTION_BLUETOOTH: 1
ENT_AUDIO: 0
ANTENNE_1: 1
ANTENNE_2: 1
NB_SATELLITES_FLAG: 3
RADAR: 1
BT: 1
ATT_DG_RADIO_NUM: 3
ATT_DG_USB: 1
ATT_DG_JDA: 1
ATT_DG_RAD_SEUIL: 0
ATT_DG_RAD_NUM_SEUIL: 80
ATT_DG_VITESSE_LIMIT: 1
ATT_DG_HIFI: 3
ATT_DG_SID: 58
ATT_DG_INTERNET: 1
AM: 1
FADER: 1
NB_ANTENNE: 0
ATT_DG_TYPE_CLIM: 3
ATT_DG_TYPE_DIST: 0
ATT_DG_PRES_AC_MAX: 0
ATT_DG_CHX_CAL_ECRAN: 3
ATT_DG_ECRAN_SECOND: 0
ENERGY_SAVER_PUSH: 0
AIRFLOW_BY_LEVEL: 0
TEMP_ADJUST: 1
AIRFLOW_DIR_ADJUST: 1
CLIM_AUTO: 1
AIRFLOW_BY_INC: 1
SMARTAPPS: 1
DG_EXP_NAV_JVRP16: 0
ATT_DG_HY_PRESENT: 0
DAT_DG_ACV_PUSH_LED: 0
DAT_DG_CHECK_PUSH: 1
DAT_DG_WELCOMEPAGE_C: 1
DG_SAM_PUSH_POS: 6
DG_CPAS_PUSH_POS: 0
DG_ARTIV_PUSH_POS: 8
DG_AFIL_PUSH_POS: 0
DG_LKA_PUSH_POS: 0
DG_AAS_PUSH_POS: 3
DG_PVC_PUSH_POS: 0
DG_CAFR_PUSH_POS: 2
DG_MPD_PUSH_LED_POS: 0
DG_STT_PUSH_LED_POS: 0
DG_SAM_PUSH_PANEL: 0
DG_CPAS_PUSH_PANEL: 0
DG_DGSI_PUSH_PANEL: 0
DG_ARTIV_PUSH_PANEL: 0
DG_AFIL_PUSH_PANEL: 0
DG_LKA_PUSH_PANEL: 0
DG_AAS_PUSH_PANEL: 0
DG_PVC_PUSH_PANEL: 0
DG_CAFR_PUSH_PANEL: 0
ATT_DG_EXP_NAV_ILV: 1
DAT_DG_LKA_PUSH_LED: 0
DAT_DG_UREA: 0
DAT_DG_TYRES_PRES: 1
DAT_DG_DRIVE_IVTRA: 0
DAT_DG_DRIVE_ICC_SET: 0
DAT_DG_DRIVE_ASRPLUS: 0
DAT_DG_LUM_MANAG: 1
DAT_DG_ALARM_HISTORY: 1
DAT_DG_ALARM: 0
DAT_DG_LANGUAGE: 0
OPTION_SD_MEDIA_EVO: 0
DAT_DG_HY_BAT_LEVEL9: 100
DG_MPD_PUSH_PANEL: 1
DG_STT_PUSH_PANEL: 0
DG_ACV_PUSH_POS: 0
DG_DGSI_PUSH_POS: 7
DG_HY_BAT_HYST_DOWN: 2
DG_ACV_PUSH_PANEL: 0
DAT_DG_HY_BAT_LEVEL0: 0
DAT_DG_ARTIV_PUSHES: 0
DAT_DG_HY_BAT_LEVEL8: 95
DAT_DG_HY_BAT_LEVEL7: 83
DAT_DG_HY_BAT_LEVEL6: 70
DAT_DG_HY_BAT_LEVEL5: 57
DAT_DG_HY_BAT_LEVEL4: 44
DAT_DG_HY_BAT_LEVEL3: 31
DAT_DG_HY_BAT_LEVEL2: 18
DAT_DG_HY_BAT_LEVEL1: 5
DG_HY_BAT_HYST_UP: 2
CPUSH_DOMELIGHT: 0
INIT_DSGI: 1
CURRENT_PROFILE: 0
UNITS_LANGUAGE: 1
XVV_MAX: 180
XVV_MIN: 40
MENU_AMBIANCE_8: 0
MENU_AMBIANCE_7: 0
MENU_AMBIANCE_6: 0
MENU_AMBIANCE_5: 0
MENU_AMBIANCE_4: 0
MENU_AMBIANCE_3: 1
MENU_AMBIANCE_2: 1
MENU_AMBIANCE_1: 1
FAMILY_NAME_1: 3
FAMILY_NAME_2: 2
FAMILY_NAME_3: 6
FAMILY_NAME_4: 1
NOM_ITEM4_FAMILLE__4: 24
NOM_ITEM3_FAMILLE__4: 28
REAR_VC: 0
CONF_DOP: 1
SEAT_NB: 0
CPUSH_ALARMLOG: 0
CPUSH_BLACK_PANEL: 0
CPUSH_COLORCLUST: 0
CPUSH_CHECK: 0
NOM_ITEM1_FAMILLE__1: 3
NOM_ITEM2_FAMILLE__1: 15
NOM_ITEM3_FAMILLE__1: 0
SOUNDHARMONY: 1
VEHICLE: 1
AMBIANCE_DEFAULT: 3
LVV_MAX: 180
LVV_MIN: 40
RVV_MAX: 180
RVV_MIN: 40
DATE_TIME_DISP: 1
DATE_TIME_MENU: 1
DATE_TIME_ZONE: 52
DATE_FORMAT_INIT: 0
NOT_DATE: 0
CONF_RVVI: 0
RLVV_MEMORIZATION: 0
RLVV_SELECTION: 0
ICE_WARNING_TEMP: 86
NOM_ITEM2_FAMILLE__4: 0
NOM_ITEM1_FAMILLE__4: 0
NOM_ITEM1_FAMILLE__3: 6
NOM_ITEM2_FAMILLE__3: 0
NOM_ITEM3_FAMILLE__3: 0
NOM_ITEM4_FAMILLE__3: 0
NOM_ITEM4_FAMILLE__2: 0
NOM_ITEM3_FAMILLE__2: 0
NOM_ITEM2_FAMILLE__2: 9
NOM_ITEM1_FAMILLE__2: 7
XVV_DMD: 1
DATE_TIME_SYNC: 1
DATE_TIME_SYNC_INIT: 1
DATE_TIME_ZONE_INIT: 52
ENGINEERING_MODE: 1
NB_MICRO: 0
CONNECT_WIFI_CLI: 1
CONNECT_WIFI_AP: 1
HY_HISTO_PRESENT: 0
DISPLAY_RISK_ALERT: 1
EXPORT_TUNER: 1
SELECT_CARTO_NAV: 0
RVC_LEGAL: 0
RVC_REF: 0
OBC_PERMANENTPAGE: 1
PVC_PUSH: 0
PVC_MENU: 1
ODO_PARTIAL: 1
OBC: 1
OBC_STT: 1
OBC_POPUPPAGE: 0
OBC_PUSH: 0
AAS_PUSH_LED: 1
PVC_LEGAL: 1
PVC_TYPE: 1
OBC_PAGE: 0
MAINTENANCE: 0
CLIM_PRECOND: 0
HW_WIFI: 1
DIAG_ML_ON_OFF: 1
CMD_TYP: 3
DG_GREEN_CRITERIA: 0
CLIM_ACTIVATION: 1
SPEED_SVR: 254
PRECOND_PUSH_LED: 0
PRECOND_PUSH_PANEL: 0
PRECOND_PUSH_POS: 0
LVDS_SPEED: 1
LVDS_BWS_CONFIG: 1
NOM_ITEM10_FAMILLE_4: 0
NOM_ITEM9_FAMILLE_4: 0
NOM_ITEM8_FAMILLE_4: 0
NOM_ITEM7_FAMILLE_4: 0
NOM_ITEM6_FAMILLE_4: 0
NOM_ITEM5_FAMILLE_4: 0
NOM_ITEM10_FAMILLE_3: 0
NOM_ITEM9_FAMILLE_3: 0
NOM_ITEM8_FAMILLE_3: 0
NOM_ITEM10_FAMILLE_2: 0
NOM_ITEM9_FAMILLE_2: 0
NOM_ITEM8_FAMILLE_2: 0
NOM_ITEM7_FAMILLE_2: 0
NOM_ITEM6_FAMILLE_2: 0
NOM_ITEM4_FAMILLE__1: 0
OPTION_COLORATION_MO: 1
TYPE_COLOR_MOTEUR: 1
DIPO_ON_OFF: 1
PARAM_EFF_COLOR_MOTE: 1
NOM_ITEM5_FAMILLE_2: 0
NOM_ITEM10_FAMILLE_1: 0
NOM_ITEM9_FAMILLE_1: 0
NOM_ITEM8_FAMILLE_1: 0
NOM_ITEM7_FAMILLE_1: 0
NOM_ITEM6_FAMILLE_1: 0
NOM_ITEM5_FAMILLE_1: 0
NOM_ITEM5_FAMILLE_3: 0
NOM_ITEM6_FAMILLE_3: 0
NOM_ITEM7_FAMILLE_3: 0
ATT_DG_CONF_INTERNET: 1
TYPE_ENERGIE: 0
ATT_DG_USB_2ND: 0
ATT_DG_CAFR_PUSH: 1
ATT_DG_ARTIV_PUSH: 0
ATT_DG_AFIL_PUSH: 0
ATT_DG_MPD_PUSH: 0
ATT_DG_SAM_PUSH: 0
ATT_DG_CITYPARK_PUSH: 0
ATT_DG_STT_PUSH: 0
ATT_DG_PRES_RECYCL: 1
ATT_DG_PRES_CLIM_AR: 0
ATT_DG_EXP_NAV_CSR: 0
ATT_DG_EXP_NAV_CAR: 1
ATT_DG_EXP_NAV_JVAR: 1
ATT_DG_PRES_TYPAGE: 1
ATT_DG_PRES_AQS: 0
ATT_DG_TYPE_MIX: 1
REAR_SIDE_HOR_ENL_RA: 100
REAR_SIDE_ENL_ORIGIN: 0
REAR_SIDE_VER_ENL_RA: 100
REAR_STD_HOR_ENL_RAT: 100
DYNAMIC_MODE: 1
REAR_STD_VERT_ENL_OR: 0
REAR_STD_VERT_ENL_RA: 100
TRAILER_HOOK_HEIGHT: 506
TRAILER_HOOK_LENGTH: 99
REAR_REAL_TOP_VIEW_H: 2050
OPTION_IDVR: 0
ICALL_VHL_SPEAKER: 1
MOOD_GRID: 0
CLIM_MONO: 2
BCALL_VHL_SPEAKER: 1
AAP_ON_OFF: 1
AUDIO_PRESET_LIVE: 1
VIDEO_CODING_1: 0
VIDEO_CODING_2: 1
IDVR_LDW_PUSH_LED: 0
IDVR_LDW_PSH_LED_PNE: 0
IDVR_FCW_PUSH_LED_PN: 0
IDVR_FCW_PUSH_LED_PO: 0
IDVR_LDW_PUSH_LED_PO: 0
CONF_WEB_PORTAL: 1
PERSO: 0
IDVR_FCW_PUSH_LED: 0
LOI_DX: 1
TYPE_EXPORT_VIDEO: 0
EXPORT_INFO_TRAFFIC: 1
ACQ_IHM_COLOR: 0
XVV_STOPADJUST: 0
RVV_RVVI_PUSH_LED: 0
CLIM_RECALL_INFO: 1
OPTION_WIFI: 1
DAT_DG_CARLINE: 14
DY_PARAMETER_1: 128
DY_PARAMETER_2: 40
RDS_FOLLOW_UP: 1
REAR_CAMERA_YAW: 1800
REAR_CAMERA_PITCH: 487
REAR_CAMERA_ROLL: 1800
REAR_CAMERA_Z: 800
REAR_CAMERA_Y: 3059
REAR_CAMERA_X: 3828
RVV_RVVI_PUSH_LED_PA: 0
RVV_RVVI_PUSH_LED_PO: 0
ATT_DG_AVC: 1
TRAJECTORY_LIN_REA_W: 6
DIST_LINE_REAR_WID_2: 2
DIST_LINE_REAR_WID_1: 4
REAR_BUMPER_EDGE_HEI: 598
WHEELBASE: 1620
REAR_OVERHANG: 620
FRONT_OVERHANG: 712
DOORS_TYPE: 0
VEHICLE_WIDTH: 543
DIST_LINE_REAR_W_03: 8
OPTION_EXPORT_MEDIA: 1
TYPE_EXPORT_MEDIA: 0
AMPLI_SURRND_BY_CDC: 0
ASR_PUSH_LED_PANEL: 0
ASR_PUSH_LED_POS: 4
ASR_PUSH_LED: 0
CLIM_OFF_BUTTON: 0
PRESENCE_AAS_ADJUST: 0
OPT_REMOTE_MNGT_VHL: 0
TYPE_EXP_MEDIA_CAN: 0
PANORAMIC_VC: 1
CLIM_IONISOR_CFGS: 0
CLIM_STATUSLINE: 1
BEIDOU_GPS_CHOICE: 0
CENTRAL_SPK_SETTING: 0
ODS_TYPE: 0
UNKNOWN_1: 0
UNKNOWN_2: 1
UNKNOWN_3: 1
UNKNOWN_4: 0
UNKNOWN_5: 1
UNKNOWN_6: 0
UNKNOWN_7: 0
T_EXT: 1
AAS: 1
COUNTRY: 0
OPTION_BLUETOOTH: 1
ENT_AUDIO: 0
ANTENNE_1: 1
ANTENNE_2: 1
RADAR: 1
BT: 1
ATT_DG_RADIO_NUM: 3
ATT_DG_USB: 1
ATT_DG_JDA: 1
ATT_DG_RAD_SEUIL: 0
ATT_DG_HIFI: 3
ATT_DG_SID: 58
ATT_DG_INTERNET: 1
AM: 1
FADER: 1
NB_ANTENNE: 0
ATT_DG_TYPE_CLIM: 3
ATT_DG_TYPE_DIST: 0
AIRFLOW_BY_LEVEL: 0
TEMP_ADJUST: 1
CLIM_AUTO: 1
AIRFLOW_BY_INC: 1
SMARTAPPS: 1
DG_SAM_PUSH_POS: 6
DG_CPAS_PUSH_POS: 0
DG_AFIL_PUSH_POS: 0
DG_LKA_PUSH_POS: 0
DG_AAS_PUSH_POS: 3
DG_PVC_PUSH_POS: 0
DG_CAFR_PUSH_POS: 2
DAT_DG_UREA: 0
DAT_DG_LUM_MANAG: 1
DAT_DG_ALARM: 0
DAT_DG_LANGUAGE: 0
DG_ACV_PUSH_POS: 0
DG_DGSI_PUSH_POS: 7
CPUSH_DOMELIGHT: 0
INIT_DSGI: 1
CURRENT_PROFILE: 0
UNITS_LANGUAGE: 1
XVV_MAX: 180
XVV_MIN: 40
MENU_AMBIANCE_8: 0
MENU_AMBIANCE_7: 0
MENU_AMBIANCE_6: 0
MENU_AMBIANCE_5: 0
MENU_AMBIANCE_4: 0
MENU_AMBIANCE_3: 1
MENU_AMBIANCE_2: 1
MENU_AMBIANCE_1: 1
FAMILY_NAME_1: 3
FAMILY_NAME_2: 2
FAMILY_NAME_3: 6
FAMILY_NAME_4: 1
REAR_VC: 0
CONF_DOP: 1
SEAT_NB: 0
CPUSH_ALARMLOG: 0
CPUSH_COLORCLUST: 0
CPUSH_CHECK: 0
SOUNDHARMONY: 1
VEHICLE: 1
AMBIANCE_DEFAULT: 3
LVV_MAX: 180
LVV_MIN: 40
RVV_MAX: 180
RVV_MIN: 40
DATE_TIME_DISP: 1
DATE_TIME_MENU: 1
DATE_TIME_ZONE: 52
DATE_FORMAT_INIT: 0
NOT_DATE: 0
CONF_RVVI: 0
RLVV_SELECTION: 0
XVV_DMD: 1
DATE_TIME_SYNC: 1
ENGINEERING_MODE: 1
NB_MICRO: 0
CONNECT_WIFI_CLI: 1
CONNECT_WIFI_AP: 1
HY_HISTO_PRESENT: 0
EXPORT_TUNER: 1
SELECT_CARTO_NAV: 0
RVC_LEGAL: 0
RVC_REF: 0
PVC_PUSH: 0
PVC_MENU: 1
ODO_PARTIAL: 1
OBC: 1
OBC_STT: 1
OBC_POPUPPAGE: 0
OBC_PUSH: 0
AAS_PUSH_LED: 1
PVC_LEGAL: 1
PVC_TYPE: 1
OBC_PAGE: 0
MAINTENANCE: 0
CLIM_PRECOND: 0
HW_WIFI: 1
DIAG_ML_ON_OFF: 1
CMD_TYP: 3
CLIM_ACTIVATION: 1
SPEED_SVR: 254
PRECOND_PUSH_LED: 0
PRECOND_PUSH_POS: 0
LVDS_SPEED: 1
LVDS_BWS_CONFIG: 1
DIPO_ON_OFF: 1
TYPE_ENERGIE: 0
ATT_DG_USB_2ND: 0
ATT_DG_CAFR_PUSH: 1
ATT_DG_AFIL_PUSH: 0
ATT_DG_MPD_PUSH: 0
ATT_DG_SAM_PUSH: 0
ATT_DG_STT_PUSH: 0
ATT_DG_PRES_AQS: 0
ATT_DG_TYPE_MIX: 1
DYNAMIC_MODE: 1
OPTION_IDVR: 0
MOOD_GRID: 0
CLIM_MONO: 2
AAP_ON_OFF: 1
VIDEO_CODING_1: 0
VIDEO_CODING_2: 1
CONF_WEB_PORTAL: 1
PERSO: 0
LOI_DX: 1
ACQ_IHM_COLOR: 0
XVV_STOPADJUST: 0
CLIM_RECALL_INFO: 1
OPTION_WIFI: 1
DAT_DG_CARLINE: 14
DY_PARAMETER_1: 128
DY_PARAMETER_2: 40
RDS_FOLLOW_UP: 1
REAR_CAMERA_Z: 800
REAR_CAMERA_Y: 3059
REAR_CAMERA_X: 3828
ATT_DG_AVC: 1
WHEELBASE: 1620
REAR_OVERHANG: 620
FRONT_OVERHANG: 712
DOORS_TYPE: 0
VEHICLE_WIDTH: 543
ASR_PUSH_LED_POS: 4
ASR_PUSH_LED: 0
CLIM_OFF_BUTTON: 0
PANORAMIC_VC: 1
CLIM_STATUSLINE: 1
ODS_TYPE: 0
UNKNOWN_1: 0
UNKNOWN_2: 1
UNKNOWN_3: 1
UNKNOWN_4: 0
UNKNOWN_5: 1
UNKNOWN_6: 0
UNKNOWN_7: 0
