Разъёмы в автомобиле (схемы подключения, маркировки)
Благодарил (а): 2814 раз
Сообщение SHKoder » 27 фев 2020, 11:01
2.54x2.54mm
(.100"x.100") Pitch
MOX
Receptacle Housing
94552
Dual Row, Breakable
8/12 Circuits
Разъёмы в автомобиле схемы подключения, маркировки - 2020-02-27_105715.png (11.29 КБ) 1150 просмотров
Circuits Order No. Polarization Lead-Free
8 pins 94552-9008
12 pins 94552-9012
Features and Benefits
• One-piece housing and secondary locking
• Breakable configuration
• Ease of use
• MQS compatible
• According to USCAR standard
Reference Information
Packaging: PK-94552-001
Mates With: 31341 series
Use With: 98658 series terminals
Designed In: Millimeters
Electrical
Voltage: 125 V RMS
Current: 7.5A max.
Contact Resistance: 7 milliohms max.
Dielectric Withstanding Voltage: 1000 V max.
Insulation Resistance: 10 Megohms min.
Mechanical
Contact Insertion Force into Housing: 15N (3.4 lb) max.
Contact Retention to Housing: 60N (13.5 lb) max.
Wire Pull-Out Force: 50N min.
Mating Force: 75N min.
Unmating Force: 75N min.
Durability: 20 cycles
Physical
Housing: PBT 20% G.F.
Сообщение SHKoder » 27 фев 2020, 11:24
4.00mm (.157") Pitch
OBD-II
Wire-to-Wire
Terminal
50420
Female
Разъёмы в автомобиле схемы подключения, маркировки - 2020-02-27_112231.png (10.9 КБ) 1145 просмотров
50420-8000
Wire Range (mm2)
AVS 0.3-0.5
AVS 0.30f-0.75f
AVSS 0.50-0.85
AVSS 0.50f-0.75f
CAVS 0.50-0.85
• Two-point contact design provides a redundant
electrical interface
• Accepts retainer for additional terminal retention
Product Specification: PS-51115-001
Packaging: Reel
Mates With: 57964
Use With: 51115 and 51116
Electrical
Voltage: 30V
Current:
Wire Size Current
AVS.AVSS 0.3 - 4A
AVS.AVSS.CAVS 0.5 - 5A
AVS.AVSS.CAVS 0.85 - 6A
Contact Resistance: 100 milliohms max.
Dielectric Withstanding Voltage: 1000V AC
Insulation Resistance: 500V DC 100 Megohms min.
Physical
Contact: Phosphor Bronze
Plating: Tin
Insulation Diameter: 1.60 to 2.30mm (.024 to .091")
Сообщение SHKoder » 04 мар 2020, 15:05
Разъёмы в автомобиле схемы подключения, маркировки - 2020-03-04_150112.png (22.51 КБ) 1012 просмотров
Используется для подключения питания экрана SMEG и в других местах.
1379029-1 - Black NR
1379029-2 - White BA
1379029-3 - Blue BE
1379029-4 - Yellow JN
1379029-5 - Gray GR
1379029-6 - Brown MR
https://www.mouser.com/datasheet/2/418/ ... 647495.pdf
Сообщение SHKoder » 12 мар 2020, 14:24
SHIELD & LEVER, FOR MQS, 18 POS (90)
Разъёмы в автомобиле схемы подключения, маркировки - 28218454.jpg (8.76 КБ) 914 просмотров
Accessory Type Cover
For Use With 18 Position Receptacle Housings
No. of Positions 18Ways
Operating Temperature Max 100°C
Operating Temperature Min -40°C
1379101-1 NR
1379101-2 BA
1379101-3 BE
1379101-4 MR
1379101-5 VE
MQS SOCKET HSG 18W GENE 2
Разъёмы в автомобиле схемы подключения, маркировки - 2020-03-12_141528.png (7.76 КБ) 914 просмотров
Cable Exit Angle: 180°;
Body Material: PBT;
Color: Black;
Number of Rows: 2;
Number of Positions: 18;
Mating Tab Width: 0.025in;
1379102-1
Рекомендуется использовать пины 144969-1
Сообщение SHKoder » 12 мар 2020, 14:40
SHIELD & LEVER, FOR MQS, 12 POS (90)
Разъёмы в автомобиле схемы подключения, маркировки - 2020-03-12_143923.png (6.99 КБ) 909 просмотров
For Use With 12 Position Receptacle Housings
1379096-1 MR
1379096-2 BE
1379096-3 NR
MQS SOCKET HSG 12W GENE 2
Разъёмы в автомобиле схемы подключения, маркировки - 2020-03-12_143831.png (8.5 КБ) 909 просмотров
No. of Positions 12 Ways
1379219-1
Сообщение SHKoder » 19 мар 2020, 00:48
Разъёмы в автомобиле схемы подключения, маркировки  - IMG_20200319_004754.jpg
Разъёмы в автомобиле схемы подключения, маркировки - IMG_20200319_004754.jpg (74.04 КБ) 754 просмотра
Разъёмы в автомобиле схемы подключения, маркировки  - IMG_20200319_004807.jpg
Разъёмы в автомобиле схемы подключения, маркировки - IMG_20200319_004807.jpg (66.12 КБ) 754 просмотра
Datasheet
https://www.chipdip.ru/product/968075-2 ... e-17-13awg
https://www.te.com/usa-en/product-1241765-2.html
Сообщение SHKoder » 21 май 2020, 23:48
Вернуться в «FAQ по C4 Седан»
