[Лаборатория] Config SQLite
Программируем своими руками
Благодарил (а): 3221 раз
Сообщение SHKoder » 03 июн 2020, 13:40
Peugeot 308
Albin link
CDC: 1
T_EXT: 1
AAS: 1
COUNTRY: 0
OPTION_BLUETOOTH: 1
ENT_AUDIO: 0
ANTENNE_1: 1
ANTENNE_2: 1
NB_SATELLITES_FLAG: 3
RADAR: 1
BT: 1
ATT_DG_RADIO_NUM: 3
ATT_DG_USB: 1
ATT_DG_JDA: 1
ATT_DG_RAD_SEUIL: 0
ATT_DG_RAD_NUM_SEUIL: 80
ATT_DG_VITESSE_LIMIT: 1
ATT_DG_HIFI: 3
ATT_DG_SID: 58
ATT_DG_INTERNET: 1
AM: 1
FADER: 1
NB_ANTENNE: 0
ATT_DG_TYPE_CLIM: 3
ATT_DG_TYPE_DIST: 0
ATT_DG_PRES_AC_MAX: 0
ATT_DG_CHX_CAL_ECRAN: 3
ATT_DG_ECRAN_SECOND: 0
ENERGY_SAVER_PUSH: 0
AIRFLOW_BY_LEVEL: 0
TEMP_ADJUST: 1
AIRFLOW_DIR_ADJUST: 1
CLIM_AUTO: 1
AIRFLOW_BY_INC: 1
SMARTAPPS: 1
DG_EXP_NAV_JVRP16: 0
ATT_DG_HY_PRESENT: 0
DAT_DG_ACV_PUSH_LED: 0
DAT_DG_CHECK_PUSH: 1
DAT_DG_WELCOMEPAGE_C: 1
DG_SAM_PUSH_POS: 6
DG_CPAS_PUSH_POS: 0
DG_ARTIV_PUSH_POS: 8
DG_AFIL_PUSH_POS: 0
DG_LKA_PUSH_POS: 0
DG_AAS_PUSH_POS: 3
DG_PVC_PUSH_POS: 0
DG_CAFR_PUSH_POS: 2
DG_MPD_PUSH_LED_POS: 0
DG_STT_PUSH_LED_POS: 0
DG_SAM_PUSH_PANEL: 0
DG_CPAS_PUSH_PANEL: 0
DG_DGSI_PUSH_PANEL: 0
DG_ARTIV_PUSH_PANEL: 0
DG_AFIL_PUSH_PANEL: 0
DG_LKA_PUSH_PANEL: 0
DG_AAS_PUSH_PANEL: 0
DG_PVC_PUSH_PANEL: 0
DG_CAFR_PUSH_PANEL: 0
ATT_DG_EXP_NAV_ILV: 1
DAT_DG_LKA_PUSH_LED: 0
DAT_DG_UREA: 0
DAT_DG_TYRES_PRES: 1
DAT_DG_DRIVE_IVTRA: 0
DAT_DG_DRIVE_ICC_SET: 0
DAT_DG_DRIVE_ASRPLUS: 0
DAT_DG_LUM_MANAG: 1
DAT_DG_ALARM_HISTORY: 1
DAT_DG_ALARM: 0
DAT_DG_LANGUAGE: 0
OPTION_SD_MEDIA_EVO: 0
DAT_DG_HY_BAT_LEVEL9: 100
DG_MPD_PUSH_PANEL: 1
DG_STT_PUSH_PANEL: 0
DG_ACV_PUSH_POS: 0
DG_DGSI_PUSH_POS: 7
DG_HY_BAT_HYST_DOWN: 2
DG_ACV_PUSH_PANEL: 0
DAT_DG_HY_BAT_LEVEL0: 0
DAT_DG_ARTIV_PUSHES: 0
DAT_DG_HY_BAT_LEVEL8: 95
DAT_DG_HY_BAT_LEVEL7: 83
DAT_DG_HY_BAT_LEVEL6: 70
DAT_DG_HY_BAT_LEVEL5: 57
DAT_DG_HY_BAT_LEVEL4: 44
DAT_DG_HY_BAT_LEVEL3: 31
DAT_DG_HY_BAT_LEVEL2: 18
DAT_DG_HY_BAT_LEVEL1: 5
DG_HY_BAT_HYST_UP: 2
CPUSH_DOMELIGHT: 0
INIT_DSGI: 1
CURRENT_PROFILE: 0
UNITS_LANGUAGE: 1
XVV_MAX: 180
XVV_MIN: 40
MENU_AMBIANCE_8: 0
MENU_AMBIANCE_7: 0
MENU_AMBIANCE_6: 0
MENU_AMBIANCE_5: 0
MENU_AMBIANCE_4: 0
MENU_AMBIANCE_3: 1
MENU_AMBIANCE_2: 1
MENU_AMBIANCE_1: 1
FAMILY_NAME_1: 3
FAMILY_NAME_2: 2
FAMILY_NAME_3: 6
FAMILY_NAME_4: 1
NOM_ITEM4_FAMILLE__4: 24
NOM_ITEM3_FAMILLE__4: 28
REAR_VC: 0
CONF_DOP: 1
SEAT_NB: 0
CPUSH_ALARMLOG: 0
CPUSH_BLACK_PANEL: 0
CPUSH_COLORCLUST: 0
CPUSH_CHECK: 0
NOM_ITEM1_FAMILLE__1: 3
NOM_ITEM2_FAMILLE__1: 15
NOM_ITEM3_FAMILLE__1: 0
SOUNDHARMONY: 1
VEHICLE: 1
AMBIANCE_DEFAULT: 3
LVV_MAX: 180
LVV_MIN: 40
RVV_MAX: 180
RVV_MIN: 40
DATE_TIME_DISP: 1
DATE_TIME_MENU: 1
DATE_TIME_ZONE: 52
DATE_FORMAT_INIT: 0
NOT_DATE: 0
CONF_RVVI: 0
RLVV_MEMORIZATION: 0
RLVV_SELECTION: 0
ICE_WARNING_TEMP: 86
NOM_ITEM2_FAMILLE__4: 0
NOM_ITEM1_FAMILLE__4: 0
NOM_ITEM1_FAMILLE__3: 6
NOM_ITEM2_FAMILLE__3: 0
NOM_ITEM3_FAMILLE__3: 0
NOM_ITEM4_FAMILLE__3: 0
NOM_ITEM4_FAMILLE__2: 0
NOM_ITEM3_FAMILLE__2: 0
NOM_ITEM2_FAMILLE__2: 9
NOM_ITEM1_FAMILLE__2: 7
XVV_DMD: 1
DATE_TIME_SYNC: 1
DATE_TIME_SYNC_INIT: 1
DATE_TIME_ZONE_INIT: 52
ENGINEERING_MODE: 1
NB_MICRO: 0
CONNECT_WIFI_CLI: 1
CONNECT_WIFI_AP: 1
HY_HISTO_PRESENT: 0
DISPLAY_RISK_ALERT: 1
EXPORT_TUNER: 1
SELECT_CARTO_NAV: 0
RVC_LEGAL: 0
RVC_REF: 0
OBC_PERMANENTPAGE: 1
PVC_PUSH: 0
PVC_MENU: 1
ODO_PARTIAL: 1
OBC: 1
OBC_STT: 1
OBC_POPUPPAGE: 0
OBC_PUSH: 0
AAS_PUSH_LED: 1
PVC_LEGAL: 1
PVC_TYPE: 1
OBC_PAGE: 0
MAINTENANCE: 0
CLIM_PRECOND: 0
HW_WIFI: 1
DIAG_ML_ON_OFF: 1
CMD_TYP: 3
DG_GREEN_CRITERIA: 0
CLIM_ACTIVATION: 1
SPEED_SVR: 254
PRECOND_PUSH_LED: 0
PRECOND_PUSH_PANEL: 0
PRECOND_PUSH_POS: 0
LVDS_SPEED: 1
LVDS_BWS_CONFIG: 1
NOM_ITEM10_FAMILLE_4: 0
NOM_ITEM9_FAMILLE_4: 0
NOM_ITEM8_FAMILLE_4: 0
NOM_ITEM7_FAMILLE_4: 0
NOM_ITEM6_FAMILLE_4: 0
NOM_ITEM5_FAMILLE_4: 0
NOM_ITEM10_FAMILLE_3: 0
NOM_ITEM9_FAMILLE_3: 0
NOM_ITEM8_FAMILLE_3: 0
NOM_ITEM10_FAMILLE_2: 0
NOM_ITEM9_FAMILLE_2: 0
NOM_ITEM8_FAMILLE_2: 0
NOM_ITEM7_FAMILLE_2: 0
NOM_ITEM6_FAMILLE_2: 0
NOM_ITEM4_FAMILLE__1: 0
OPTION_COLORATION_MO: 1
TYPE_COLOR_MOTEUR: 1
DIPO_ON_OFF: 1
PARAM_EFF_COLOR_MOTE: 1
NOM_ITEM5_FAMILLE_2: 0
NOM_ITEM10_FAMILLE_1: 0
NOM_ITEM9_FAMILLE_1: 0
NOM_ITEM8_FAMILLE_1: 0
NOM_ITEM7_FAMILLE_1: 0
NOM_ITEM6_FAMILLE_1: 0
NOM_ITEM5_FAMILLE_1: 0
NOM_ITEM5_FAMILLE_3: 0
NOM_ITEM6_FAMILLE_3: 0
NOM_ITEM7_FAMILLE_3: 0
ATT_DG_CONF_INTERNET: 1
TYPE_ENERGIE: 0
ATT_DG_USB_2ND: 0
ATT_DG_CAFR_PUSH: 1
ATT_DG_ARTIV_PUSH: 0
ATT_DG_AFIL_PUSH: 0
ATT_DG_MPD_PUSH: 0
ATT_DG_SAM_PUSH: 0
ATT_DG_CITYPARK_PUSH: 0
ATT_DG_STT_PUSH: 0
ATT_DG_PRES_RECYCL: 1
ATT_DG_PRES_CLIM_AR: 0
ATT_DG_EXP_NAV_CSR: 0
ATT_DG_EXP_NAV_CAR: 1
ATT_DG_EXP_NAV_JVAR: 1
ATT_DG_PRES_TYPAGE: 1
ATT_DG_PRES_AQS: 0
ATT_DG_TYPE_MIX: 1
REAR_SIDE_HOR_ENL_RA: 100
REAR_SIDE_ENL_ORIGIN: 0
REAR_SIDE_VER_ENL_RA: 100
REAR_STD_HOR_ENL_RAT: 100
DYNAMIC_MODE: 1
REAR_STD_VERT_ENL_OR: 0
REAR_STD_VERT_ENL_RA: 100
TRAILER_HOOK_HEIGHT: 506
TRAILER_HOOK_LENGTH: 99
REAR_REAL_TOP_VIEW_H: 2050
OPTION_IDVR: 0
ICALL_VHL_SPEAKER: 1
MOOD_GRID: 0
CLIM_MONO: 2
BCALL_VHL_SPEAKER: 1
AAP_ON_OFF: 1
AUDIO_PRESET_LIVE: 1
VIDEO_CODING_1: 0
VIDEO_CODING_2: 1
IDVR_LDW_PUSH_LED: 0
IDVR_LDW_PSH_LED_PNE: 0
IDVR_FCW_PUSH_LED_PN: 0
IDVR_FCW_PUSH_LED_PO: 0
IDVR_LDW_PUSH_LED_PO: 0
CONF_WEB_PORTAL: 1
PERSO: 0
IDVR_FCW_PUSH_LED: 0
LOI_DX: 1
TYPE_EXPORT_VIDEO: 0
EXPORT_INFO_TRAFFIC: 1
ACQ_IHM_COLOR: 0
XVV_STOPADJUST: 0
RVV_RVVI_PUSH_LED: 0
CLIM_RECALL_INFO: 1
OPTION_WIFI: 1
DAT_DG_CARLINE: 14
DY_PARAMETER_1: 128
DY_PARAMETER_2: 40
RDS_FOLLOW_UP: 1
REAR_CAMERA_YAW: 1800
REAR_CAMERA_PITCH: 487
REAR_CAMERA_ROLL: 1800
REAR_CAMERA_Z: 800
REAR_CAMERA_Y: 3059
REAR_CAMERA_X: 3828
RVV_RVVI_PUSH_LED_PA: 0
RVV_RVVI_PUSH_LED_PO: 0
ATT_DG_AVC: 1
TRAJECTORY_LIN_REA_W: 6
DIST_LINE_REAR_WID_2: 2
DIST_LINE_REAR_WID_1: 4
REAR_BUMPER_EDGE_HEI: 598
WHEELBASE: 1620
REAR_OVERHANG: 620
FRONT_OVERHANG: 712
DOORS_TYPE: 0
VEHICLE_WIDTH: 543
DIST_LINE_REAR_W_03: 8
OPTION_EXPORT_MEDIA: 1
TYPE_EXPORT_MEDIA: 0
AMPLI_SURRND_BY_CDC: 0
ASR_PUSH_LED_PANEL: 0
ASR_PUSH_LED_POS: 4
ASR_PUSH_LED: 0
CLIM_OFF_BUTTON: 0
PRESENCE_AAS_ADJUST: 0
OPT_REMOTE_MNGT_VHL: 0
TYPE_EXP_MEDIA_CAN: 0
PANORAMIC_VC: 1
CLIM_IONISOR_CFGS: 0
CLIM_STATUSLINE: 1
BEIDOU_GPS_CHOICE: 0
CENTRAL_SPK_SETTING: 0
ODS_TYPE: 0
UNKNOWN_1: 0
UNKNOWN_2: 1
UNKNOWN_3: 1
UNKNOWN_4: 0
UNKNOWN_5: 1
UNKNOWN_6: 0
UNKNOWN_7: 0
Сообщение SHKoder » 03 июн 2020, 13:43
Peugeot 308
VLud link
CDC: 0 (0)
T_EXT: 1 (1)
AAS: 1 (01)
COUNTRY: 0 (000)
OPTION_BLUETOOTH: 1 (1)
ENT_AUDIO: 0 (0)
ANTENNE_1: 1 (1)
ANTENNE_2: 1 (1)
NB_SATELLITES_FLAG: 3 (0011)
RADAR: 1 (1)
BT: 1 (1)
ATT_DG_RADIO_NUM: 3 (11)
ATT_DG_USB: 1 (1)
ATT_DG_JDA: 1 (1)
ATT_DG_RAD_SEUIL (BIN?): 0 (00)
ATT_DG_RAD_NUM_SEUIL (HEX): 80 (50)
ATT_DG_VITESSE_LIMIT: 1 (1)
ATT_DG_HIFI: 3 (011)
ATT_DG_SID (HEX): 58 (3A)
ATT_DG_INTERNET: 1 (1)
AM: 1 (1)
FADER: 1 (1)
NB_ANTENNE: 0 (0)
ATT_DG_TYPE_CLIM: 3 (011)
ATT_DG_TYPE_DIST: 0 (0)
ATT_DG_PRES_AC_MAX: 0 (0)
ATT_DG_CHX_CAL_ECRAN (HEX): 3 (3)
ATT_DG_ECRAN_SECOND: 0 (00)
ENERGY_SAVER_PUSH: 0 (0)
AIRFLOW_BY_LEVEL: 0 (0)
TEMP_ADJUST: 1 (1)
AIRFLOW_DIR_ADJUST: 1 (1)
CLIM_AUTO: 1 (1)
AIRFLOW_BY_INC: 1 (1)
SMARTAPPS: 1 (1)
DG_EXP_NAV_JVRP16: 0 (0)
ATT_DG_HY_PRESENT: 0 (0)
DAT_DG_ACV_PUSH_LED: 0 (0)
DAT_DG_CHECK_PUSH: 1 (1)
DAT_DG_WELCOMEPAGE_C: 1 (1)
DG_SAM_PUSH_POS: 6 (00110)
DG_CPAS_PUSH_POS: 0 (00000)
DG_ARTIV_PUSH_POS: 8 (01000)
DG_AFIL_PUSH_POS: 0 (00000)
DG_LKA_PUSH_POS: 0 (00000)
DG_AAS_PUSH_POS: 3 (00011)
DG_PVC_PUSH_POS: 0 (00000)
DG_CAFR_PUSH_POS: 2 (00010)
DG_MPD_PUSH_LED_POS: 0 (00000)
DG_STT_PUSH_LED_POS: 0 (00000)
DG_SAM_PUSH_PANEL: 0 (0)
DG_CPAS_PUSH_PANEL: 0 (0)
DG_DGSI_PUSH_PANEL: 0 (0)
DG_ARTIV_PUSH_PANEL: 0 (0)
DG_AFIL_PUSH_PANEL_0000: 0 (0)
DG_LKA_PUSH_PANEL: 0 (0)
DG_AAS_PUSH_PANEL: 0 (0)
DG_PVC_PUSH_PANEL: 0 (0)
DG_CAFR_PUSH_PANEL: 0 (0)
ATT_DG_EXP_NAV_ILV: 1 (1)
DAT_DG_LKA_PUSH_LED: 0 (0)
DAT_DG_UREA: 0 (0)
DAT_DG_TYRES_PRES: 1 (1)
DAT_DG_DRIVE_IVTRA: 0 (0)
DAT_DG_DRIVE_ICC_SET: 0 (0)
DAT_DG_DRIVE_ASRPLUS: 0 (0)
DAT_DG_LUM_MANAG: 1 (1)
DAT_DG_ALARM_HISTORY: 1 (1)
DAT_DG_ALARM: 0 (0)
DAT_DG_LANGUAGE: 0 (000000)
OPTION_SD_MEDIA_EVO: 0 (0)
DAT_DG_HY_BAT_LEVEL9: 100 (01100100)
DG_MPD_PUSH_PANEL: 1 (1)
DG_STT_PUSH_PANEL: 0 (0)
DG_ACV_PUSH_POS: 0 (00000)
DG_DGSI_PUSH_POS: 7 (00111)
DG_HY_BAT_HYST_DOWN: 2 (10)
DG_ACV_PUSH_PANEL: 0 (0)
DAT_DG_HY_BAT_LEVEL0: 0 (00000000)
DAT_DG_ARTIV_PUSHES: 0 (00)
DAT_DG_HY_BAT_LEVEL8: 95 (01011111)
DAT_DG_HY_BAT_LEVEL7: 83 (01010011)
DAT_DG_HY_BAT_LEVEL6: 70 (01000110)
DAT_DG_HY_BAT_LEVEL5: 57 (00111001)
DAT_DG_HY_BAT_LEVEL4: 44 (00101100)
DAT_DG_HY_BAT_LEVEL3: 31 (00011111)
DAT_DG_HY_BAT_LEVEL2: 18 (00010010)
DAT_DG_HY_BAT_LEVEL1: 5 (00000101)
DG_HY_BAT_HYST_UP: 2 (10)
CPUSH_DOMELIGHT: 0 (0)
INIT_DSGI: 1 (1)
CURRENT_PROFILE: 0 (0000)
UNITS_LANGUAGE: 1 (1)
XVV_MAX: 180 (10110100)
XVV_MIN: 40 (00101000)
MENU_AMBIANCE_8: 0 (0)
MENU_AMBIANCE_7: 0 (0)
MENU_AMBIANCE_6: 0 (0)
MENU_AMBIANCE_5: 0 (0)
MENU_AMBIANCE_4: 0 (0)
MENU_AMBIANCE_3: 1 (1)
MENU_AMBIANCE_2: 1 (1)
MENU_AMBIANCE_1: 1 (1)
FAMILY_NAME_1: 3 (011)
FAMILY_NAME_2: 2 (010)
FAMILY_NAME_3: 6 (110)
FAMILY_NAME_4: 1 (001)
NOM_ITEM4_FAMILLE__4: 24 (00011000)
NOM_ITEM3_FAMILLE__4: 28 (00011100)
REAR_VC: 0 (0)
CONF_DOP: 1 (1)
SEAT_NB: 0 (0)
CPUSH_ALARMLOG: 0 (0)
CPUSH_BLACK_PANEL: 0 (0)
CPUSH_COLORCLUST: 0 (0)
CPUSH_CHECK: 0 (0)
NOM_ITEM1_FAMILLE__1: 3 (00000011)
NOM_ITEM2_FAMILLE__1: 15 (00001111)
NOM_ITEM3_FAMILLE__1: 0 (00000000)
SOUNDHARMONY: 1 (1)
VEHICLE: 1 (1)
AMBIANCE_DEFAULT: 3 (011)
LVV_MAX: 180 (10110100)
LVV_MIN: 40 (00101000)
RVV_MAX: 180 (10110100)
RVV_MIN: 40 (00101000)
DATE_TIME_DISP: 1 (1)
DATE_TIME_MENU: 1 (1)
DATE_TIME_ZONE: 52 (00110100)
DATE_FORMAT_INIT: 0 (00)
NOT_DATE: 0 (00)
CONF_RVVI: 0 (0)
RLVV_MEMORIZATION: 0 (0)
RLVV_SELECTION: 0 (0)
ICE_WARNING_TEMP: 86 (01010110)
NOM_ITEM2_FAMILLE__4: 0 (00000000)
NOM_ITEM1_FAMILLE__4: 0 (00000000)
NOM_ITEM1_FAMILLE__3: 6 (00000110)
NOM_ITEM2_FAMILLE__3: 0 (00000000)
NOM_ITEM3_FAMILLE__3: 0 (00000000)
NOM_ITEM4_FAMILLE__3: 0 (00000000)
NOM_ITEM4_FAMILLE__2: 0 (00000000)
NOM_ITEM3_FAMILLE__2: 0 (00000000)
NOM_ITEM2_FAMILLE__2: 9 (00001001)
NOM_ITEM1_FAMILLE__2: 7 (00000111)
XVV_DMD: 1 (1)
DATE_TIME_SYNC: 1 (1)
DATE_TIME_SYNC_INIT: 1 (1)
DATE_TIME_ZONE_INIT: 52 (00110100)
ENGINEERING_MODE: 1 (1)
NB_MICRO: 0 (0)
CONNECT_WIFI_CLI: 1 (1)
CONNECT_WIFI_AP: 1 (1)
HY_HISTO_PRESENT: 0 (0)
DISPLAY_RISK_ALERT: 1 (1)
EXPORT_TUNER: 1 (01)
SELECT_CARTO_NAV: 0 (00000000)
RVC_LEGAL: 0 (0)
RVC_REF: 0 (0)
OBC_PERMANENTPAGE: 1 (1)
PVC_PUSH: 0 (0)
PVC_MENU: 1 (1)
ODO_PARTIAL: 1 (1)
OBC: 1 (1)
OBC_STT: 1 (1)
OBC_POPUPPAGE: 0 (0)
OBC_PUSH: 0 (0)
AAS_PUSH_LED: 1 (1)
PVC_LEGAL: 1 (1)
PVC_TYPE: 1 (01)
OBC_PAGE: 0 (00)
MAINTENANCE: 0 (0)
CLIM_PRECOND: 0 (0)
HW_WIFI: 1 (1)
DIAG_ML_ON_OFF: 1 (1)
CMD_TYP: 3 (0011)
DG_GREEN_CRITERIA: 0 (0)
CLIM_ACTIVATION: 1 (1)
SPEED_SVR: 254 (11111110)
PRECOND_PUSH_LED: 0 (0)
PRECOND_PUSH_PANEL: 0 (0)
PRECOND_PUSH_POS: 0 (00000)
LVDS_SPEED: 1 (1)
LVDS_BWS_CONFIG: 1 (1)
NOM_ITEM10_FAMILLE_4: 0 (00000000)
NOM_ITEM9_FAMILLE_4: 0 (00000000)
NOM_ITEM8_FAMILLE_4: 0 (00000000)
NOM_ITEM7_FAMILLE_4: 0 (00000000)
NOM_ITEM6_FAMILLE_4: 0 (00000000)
NOM_ITEM5_FAMILLE_4: 0 (00000000)
NOM_ITEM10_FAMILLE_3: 0 (00000000)
NOM_ITEM9_FAMILLE_3: 0 (00000000)
NOM_ITEM8_FAMILLE_3: 0 (00000000)
NOM_ITEM10_FAMILLE_2: 0 (00000000)
NOM_ITEM9_FAMILLE_2: 0 (00000000)
NOM_ITEM8_FAMILLE_2: 0 (00000000)
NOM_ITEM7_FAMILLE_2: 0 (00000000)
NOM_ITEM6_FAMILLE_2: 0 (00000000)
NOM_ITEM4_FAMILLE__1: 0 (00000000)
OPTION_COLORATION_MO: 1 (1)
TYPE_COLOR_MOTEUR: 1 (1)
DIPO_ON_OFF: 1 (1)
PARAM_EFF_COLOR_MOTE: 1 (01)
NOM_ITEM5_FAMILLE_2: 0 (00000000)
NOM_ITEM10_FAMILLE_1: 0 (00000000)
NOM_ITEM9_FAMILLE_1: 0 (00000000)
NOM_ITEM8_FAMILLE_1: 0 (00000000)
NOM_ITEM7_FAMILLE_1: 0 (00000000)
NOM_ITEM6_FAMILLE_1: 0 (00000000)
NOM_ITEM5_FAMILLE_1: 0 (00000000)
NOM_ITEM5_FAMILLE_3: 0 (00000000)
NOM_ITEM6_FAMILLE_3: 0 (00000000)
NOM_ITEM7_FAMILLE_3: 0 (00000000)
ATT_DG_CONF_INTERNET: 1 (01)
TYPE_ENERGIE: 0 (0000)
ATT_DG_USB_2ND: 0 (0)
ATT_DG_CAFR_PUSH: 1 (1)
ATT_DG_ARTIV_PUSH: 0 (0)
ATT_DG_AFIL_PUSH: 0 (0)
ATT_DG_MPD_PUSH: 0 (0)
ATT_DG_SAM_PUSH: 0 (0)
ATT_DG_CITYPARK_PUSH: 0 (0)
ATT_DG_STT_PUSH: 0 (0)
ATT_DG_PRES_RECYCL: 1 (1)
ATT_DG_PRES_CLIM_AR: 0 (0)
ATT_DG_EXP_NAV_CSR: 0 (0)
ATT_DG_EXP_NAV_CAR: 1 (1)
ATT_DG_EXP_NAV_JVAR: 1 (1)
ATT_DG_PRES_TYPAGE: 1 (1)
ATT_DG_PRES_AQS: 0 (0)
ATT_DG_TYPE_MIX: 1 (1)
REAR_SIDE_HOR_ENL_RA (HEX): 100 (64)
REAR_SIDE_ENL_ORIGIN: 0 (00)
REAR_SIDE_VER_ENL_RA (HEX): 100 (64)
REAR_STD_HOR_ENL_RAT (HEX): 100 (64)
DYNAMIC_MODE: 1 (1)
REAR_STD_VERT_ENL_OR: 0 (00)
REAR_STD_VERT_ENL_RA (HEX): 100 (64)
TRAILER_HOOK_HEIGHT (HEX): 506 (01FA)
TRAILER_HOOK_LENGTH (HEX): 99 (0063)
REAR_REAL_TOP_VIEW_H (HEX): 2050 (0802)
OPTION_IDVR: 0 (0)
ICALL_VHL_SPEAKER: 1 (1)
MOOD_GRID: 0 (0)
CLIM_MONO: 2 (10)
BCALL_VHL_SPEAKER: 1 (1)
AAP_ON_OFF: 1 (1)
AUDIO_PRESET_LIVE: 1 (1)
VIDEO_CODING_1: 0 (0)
VIDEO_CODING_2: 1 (1)
IDVR_LDW_PUSH_LED: 0 (0)
IDVR_LDW_PSH_LED_PNE: 0 (0)
IDVR_FCW_PUSH_LED_PN: 0 (0)
IDVR_FCW_PUSH_LED_PO: 0 (00000)
IDVR_LDW_PUSH_LED_PO: 0 (00000)
CONF_WEB_PORTAL: 1 (1)
PERSO: 0 (0)
IDVR_FCW_PUSH_LED: 0 (0)
LOI_DX: 1 (01)
TYPE_EXPORT_VIDEO: 0 (00)
EXPORT_INFO_TRAFFIC: 1 (1)
ACQ_IHM_COLOR: 0 (0)
XVV_STOPADJUST: 0 (0)
RVV_RVVI_PUSH_LED: 0 (0)
CLIM_RECALL_INFO: 1 (1)
OPTION_WIFI: 1 (1)
DAT_DG_CARLINE: 14 (1110)
DY_PARAMETER_1 (HEX): 128 (80)
DY_PARAMETER_2 (HEX): 40 (28)
RDS_FOLLOW_UP: 1 (1)
REAR_CAMERA_YAW (HEX): 1800 (0708)
REAR_CAMERA_PITCH (HEX): 487 (01E7)
REAR_CAMERA_ROLL (HEX): 1800 (0708)
REAR_CAMERA_Z (HEX): 800 (0320)
REAR_CAMERA_Y (HEX): 3059 (0BF3)
REAR_CAMERA_X (HEX): 3828 (0EF4)
RVV_RVVI_PUSH_LED_PA: 0 (0)
RVV_RVVI_PUSH_LED_PO: 0 (00000)
ATT_DG_AVC: 1 (1)
TRAJECTORY_LIN_REA_W (HEX): 6 (06)
DIST_LINE_REAR_WID_2 (HEX): 2 (02)
DIST_LINE_REAR_WID_1 (HEX): 4 (04)
REAR_BUMPER_EDGE_HEI (HEX): 598 (0256)
WHEELBASE (HEX): 1620 (0654)
REAR_OVERHANG (HEX): 620 (026C)
FRONT_OVERHANG (HEX): 712 (02C8)
DOORS_TYPE: 0 (00)
VEHICLE_WIDTH (HEX): 543 (021F)
DIST_LINE_REAR_W_03 (HEX): 8 (08)
OPTION_EXPORT_MEDIA: 1 (1)
TYPE_EXPORT_MEDIA: 0 (00)
AMPLI_SURRND_BY_CDC: 0 (0)
ASR_PUSH_LED_PANEL: 0 (0)
ASR_PUSH_LED_POS: 4 (00100)
ASR_PUSH_LED: 0 (0)
CLIM_OFF_BUTTON: 0 (0)
PRESENCE_AAS_ADJUST: 0 (0)
OPT_REMOTE_MNGT_VHL: 0 (0)
TYPE_EXP_MEDIA_CAN: 0 (00)
PANORAMIC_VC: 1 (1)
CLIM_IONISOR_CFGS: 0 (0)
CLIM_STATUSLINE: 1 (1)
BEIDOU_GPS_CHOICE: 0 (0)
CENTRAL_SPK_SETTING: 0 (0)
ODS_TYPE: 0 (00)
